Suspension Upgrades: Why I’m Considering a Fox vs King Setup for My 3rd Gen Tundra
Suspension is one of the most critical components when building out a 3rd Gen Tundra—especially if you’re planning to go off-road regularly. It affects everything from ride quality to handling, articulation, load capacity, and even your tire options. Right now, I’m in the final stages of deciding between Fox and King suspension for my Army Green Tundra, and I’ve spent countless hours doing research, talking to other Tundra owners, and testing setups on the trail. Here’s a breakdown of my thought process, the pros and cons of each, and what I’m leaning toward.
Why Upgrade from Stock?
Toyota did a decent job with the factory TRD Off-Road and TRD Pro suspension options, but once you start adding weight (roof rack, sliders, bumpers, lighting, bed racks, gear) and taking the truck beyond fire roads, the stock setup starts to show its limits. The ride becomes harsh, the nose dive gets worse, and articulation is limited. Not to mention, recovery from bumps at speed becomes sketchy.
For me, I want a suspension that can handle trail abuse, improve on-road manners, and support future upgrades like a front bumper and winch. That’s why I’ve narrowed it down to Fox and King—two of the top names in off-road performance.
Fox Suspension: Pros & Considerations
Fox is known for reliability, factory partnerships (they’re standard on the TRD Pro), and solid performance in various environments. If I go with Fox, I’d likely run the 2.5 DSC (Dual Speed Compression) coilovers up front and 2.5 IFP or DSC shocks in the rear with remote reservoirs.
Pros:
  • Trusted OEM partner with Toyota
  • Available through multiple trusted retailers
  • Adjustable compression settings (DSC)
  • Often comes with pre-set valving for Tundras
  • Clean anodized finish with great corrosion resistance
  • Excellent balance of price and performance
Things to Consider:
  • Not always rebuildable by just any shop (some require sending them out)
  • Less tuning range compared to King if you want a more customized setup
  • Slightly stiffer valving out of the box for some users
King Suspension: Pros & Considerations
King is the king (pun intended) of aggressive off-road performance. If you’ve ever watched desert racing or hardcore rock crawlers, odds are they’re on Kings. The 2.5 coilovers with compression adjusters and remote reservoirs are what I’d be looking at.
Pros:
  • Industry-leading performance for fast off-road driving
  • Fully rebuildable and tunable
  • Massive following and knowledge base in the off-road community
  • Premium blue anodized finish that really pops
  • Smooth, plush ride feel even at high speeds or on rough terrain
Things to Consider:
  • Higher price point
  • Requires more attention to maintenance (frequent users recommend regular rebuilds)
  • Can be overkill for lighter use or casual overlanding
  • Some setups need to be fine-tuned for daily driver comfort
Real-World Feedback & Trail Use
From the guys I’ve wheeled with in SoCal and Baja, the general consensus is this:
  • If you want low-maintenance, solid all-around performance with strong on-road manners: go Fox.
  • If you’re doing high-speed desert runs, airing out, or want total control over your setup: go King.
Both systems are overkill in the best way—and either will outperform stock by miles. My build leans toward dual-use: I daily drive the truck during the week and hit trails about twice a month. I also plan on adding a front bumper and recovery gear, so weight support is key.
What I’m Leaning Toward
Right now, I’m leaning toward Fox 2.5 DSCs, mostly for their blend of comfort, performance, and ease of ownership. They’ll handle everything I throw at them, still feel good on the highway, and give me the adjustability I want without needing full custom tuning.
That said—if a good deal pops up on a set of Kings, I wouldn’t hesitate to go that route either. Both setups are top-tier, and you can’t go wrong if you choose based on how you actually use your truck.
Final Thoughts
Suspension isn’t one-size-fits-all. Know your goals. Consider your terrain. And talk to other Tundra owners who actually use their trucks the way you plan to. Whether you go Fox, King, or something else entirely—investing in a quality setup is one of the best things you can do for your build.
Got questions on valving, spring rates, or install? Drop a comment or DM—I’ve been nerding out on this for months.
#3rdGenTundra #ToyotaTundra #SuspensionUpgrade #FoxShocks #KingShocks #OverlandRig #BuiltNotBought #TrailReady #RuggedRefined
