Morrflate TenSix Pro Worth The Money!
The first snowfall just hit California, and snow wheeling season is officially in full swing. I finally got a chance to test out my Morrflate four tire inflator system along with their TenSix Pro, and I was able to air up faster than my friend running an ARB Twin.
Don’t get me wrong, the ARB Twin is a solid compressor, but the TenSix Pro is massive and puts out around 10 CFM, which is more than the ARB. For comparison, my friend with the ARB Twin also has a homemade four tire inflator setup, but it just couldn’t keep up.
I was able to air up my 35s and my father-in-law’s 35s in the same amount of time it took him to air up his 37s. Here’s what I found that really helped with that success:
  1. The TenSix Pro outputs more CFM than the ARB Twin.
  2. The Morrflate air chucks are designed with deeper engagement on the Schrader valve, which increases airflow.
  3. The Morrflate four tire system uses high-flow fittings, which you can visibly see compared to standard fittings.
Now the only thing I need to figure out is how to mount this setup so it’s easy to use and doesn’t get in the way.
Hey yall, Just wanted to share that a...
Story time. A friend of mine recently had an...
I came from the Tacoma world, and my last...
Now that snow wheeling season is here, I’ve...
I spend a lot of time off the grid in the pack...
Could this be causing the problems with the...
The first snowfall just hit California, and...
Let me start off by saying that, personally, I...
With winter approaching I wanted to see if my...
Lift kits vs. Collar or spacer lift First list...
